We are using CALS TABLE. We would like to have pre-defined background color (let us say,gray) for our Table header in the PDF output. We have not found any way in the FOSI for this purpose. We don't want to useProcessing Instructions (PI) for this purpose. Reason behind not using PI is that PI can be inserted only in the new or updated documents, but not in the existing documents.
When existing documents are convertedto PDF, Table header should have background color. Please let us know if there is any way to have background color for Table header without using PIs. If needed, we can call ACL function inside the FOSI, if there is some solution in the ACL.
Best Regards,
Girish Kumar
