Bad Bug? (Was Re: Annoying pop-up menu)
Newbie
Steve,
I've got a nasty feeling that we've got a bad bug in our hands
(ARBORTEXT: PLEASE NOTE)
I can't unmap anything.
I think also that the @mapname mapping is not working.
What does work is "map edit Return whatever()"
so I'd suggest you change
if (!keymap_exists(sybase)){
copy_keymap edit sybase
map @sybase return return_key()
map @sybase shift-return ie hr
to
map edit return return_key()
map edit shift-return ie hr
Any explanation from ArborText as to why this is so would be more
than welcome.
Eduardo
Tags (2)
