Hello All, new to the board, so any advice would be appreciated.
I'm trying to recreate our parent company's approach to our PTC solution, however our communication with them is limited.
In doing so, I can begin to revise their approach and procedures for our needs and build our Windchill ditabase. We receive their XML files for our manuals, and I obtained a copy of their custom folders with their stylesheets. I also received their bursting rules. When I try to burst a book from the map level, it comes back with an error saying, "Cannot modify the following attributes: lang, because they are not defined. I'm still a novice, although I have gone through all the AE and WC PTC courses I can go through, but I'm not sure where to fix this issue. The attributes are defined in the bursting rules, I see language under the attribute root in the Type and Attribute Mgr in WC, and it is a valid element attribute in the dcf. Where shouldI look, or should I post this in a better suited forum?
Another question. If you're realtively new to the PTC family, and you have gone through AE, WC and Styler courses from PTC and read through a lot of their manuals, where would you look next for additional training and understanding? A lot of these courses teach basic application, but not understanding of what to do.
Thanks again!
I might try that. Up until now, I have been using the APTOBJCFG environment variable.
I'm responsible for the Windchill server test, and I have hesitated uploading the burst files to windchill at the moment. The reason is, once I successfully upload books to windchill using my parent's system, I plan to blow them away and reconfigure the bursting rules and dita filesto build a simpler, more reusable library. Unfortunately, our parent company bursted their files too deeply for acceptable reuse on our part. Although, I could upload the burst files and change them over, I just didn't want to add another variable to the plate.
Is there a difference in using the environment variable versus uploading the burst files to windchill?
Hi Clay
How do I use TerraXML to automatically burst documents in Windchill?
Alessio,
Thanks for the tip. I tried that, and it didn't work. Not your fault, I checked the lang attributes in the xml book, and noticed there was 1 that was an undeclared .psu file for british. I reverted the profile back to the original (I translated it from japanese), and that error stopped popping up (the undeclared element is still there, but it can't understand the profiling so I don't think it's trying to anymore).
However, since this book is a zipped book from the parent company's windchill, the files are still saying they are dependent on each others revision levelsto upload (Since some pulled from different books). Here is an example below. How do I prevent the books from carrying this, since for my new database they would all be A.1 anyway? The error comes back with a different referenced file every time, I assume because they are all dependent.
Also, would my windchill have a problem if the master language defined in wc is english, and the master language of the xml files was japanese (translated to english as xml:lang=en)?
I'll have to keep playing, rather than ask a question and keep trying.
I added an elemename to the locnrule to operatormanualmap, and every document that did come up appeared as operatormanualmap in WC. I was only trying to have the map burst as a map. I'm still unsure how to burst the rest into their respective types (reference, etc.). Right now, my locnrules graphic and text have no elementname associated. That seemed to be the way they came in.
My current issue is "checkin failed 1 conflict: K03_UWGM_NEVER_BEEN_UPLOADED:null" has me stumped. I will update if I figure out what that means.
Gareth,
During this whole test, I have a copy of the xml book and it's files all in one folder on my client. Everytime I make a test after changing the burst rules, I connect to my WC, and save as server object. That's where I keep getting different errors, like the one concerning language attribute, and the one concerning the revision levels. Every once in awhile, WC will upload a small bit of the files into my workspace, but they aren't in the library (although all attempts made every file an operatormanualmap). That's when i removed the operatormanualmap elementname from the locnrule. Now I get the error I just posted before this one.
This is a doozy for me!
Update:
PTC and I were able to modify the bursting docs enough to get the books to burst to windchill. The files have the correct softype, although that's really as far as we have gotten.
I'm wanting to understand and possibly undo a lot of the id referencing the parent company did. I'm still not experienced in understanding metadata rules well enough. Can someone tell me in general what these metadata rules are saying? For instance, I know that they're saying within elementname reference there is an expression listed, but I still don't understand what they are doing with them in WC. Just listing them as WC attributes, maybe? In the test with PTC, we had to remove these rules to get the book to burst, which makes me think to use them I'd have to add info in the Type manager, but I need to see if I need them in the first place. Thanks
<dmsmetadata><metadatarule elementname="reference" expr="child::title"metadata="WC_NAME_ATTR" sourcetype="text"/"><metadatarule elementname="task" expr="@outputclass"metadata="positioncode" sourcetype="text"/"><metadatarule elementname="reference"expr="/reference/titlealts/navtitle/partnum" metadata="dmc"sourcetype="text"/"><metadatarule elementname="reference"expr="/reference/titlealts/navtitle/term" metadata="category"sourcetype="text"/"><metadatarule elementname="reference"expr="/reference/titlealts/navtitle/ph" metadata="variant"sourcetype="text"/"><metadatarule elementname="reference"expr="/reference/titlealts/navtitle/tt" metadata="situation"sourcetype="text"/"><metadatarule elementname="reference" expr="@xml:lang" metadata="lang"sourcetype="text"/"></dmsmetadata>
