<br /><br />Mary,<br /><br /><br /><br /><br /><br /><br /><br />We started doing .NET on 4.4H and 5.1. AOM<br />in 5.1 is much more functional. For example, many of the events unavailable in<br />4.4H are available in 5.1. This was important for us because we were trying to<br />minimize ACL code as much as possible. We “absolutely” love .NET<br />here. Our forms behave very Windows-like and the debugger in VS.NET is very<br />good. You should be able to consume unmanaged COM DLL’s in VS.NET. As<br />Mr. Beard has indicated, reference the epic.dll in the bin directory of your<br />Epic install. <br /><br /><br /><br /><br /><br /><br /><br />Incidentally, has anyone here try to<br />deploy a .NET DLL for Epic without registering the DLL? I’m talking to<br />Microsoft and they said “registration-free COM interop” is working<br />only on Windows 2003. Our clients are running XP. They’re researching<br />this issue for us.<br /><br /><br /><br /><br /><br /><br /><br />-Gerald.<br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /> <br /><br /><br /><br /><br /><br /> <br /><br />From: -<br /> On Behalf Of Keith<br />Berard<br /><br />Sent: Thursday, October 06, 2005<br />9:56 AM<br /><br />To: adepters@arbortext.com<br /><br />Subject: Re: COM Interface to AOM<br />and .NET<br /><br /><br /><br /> <br /><br /><br /><br /><br /><br />Mary,<br /><br /><br /><br />I have done extensive work with .NET connectivity in 5.1, as well as working<br />with XUI dialogs through .NET. <br /><br /><br /><br />I have not worked with 4.4 specifically, but we too are currently stuck using<br />4.2.1 and I have had no problems calling 4.2.1 from .NET as well.<br /><br /><br /><br />Epic 5.1 does provide a .NET DLL (epic.dll in the bin dir) however I'm pretty<br />sure I had to export my own for 4.2.1.<br /><br /><br /><br />How are you exporting your epic.exe for use in .NET?<br /><br /><br /><br />Keith Berard<br /><br />XML Systems Analyst<br /><br />Milliman Care Guidelines LLC, A Milliman Company<br /><br />Tel +1 206 381.8166<br /><br />keith.berard@milliman.com<br /><br />http://www.careguidelines.com/<br /><br /><br /><br />Delivering evidence-based knowledge at the point of care <br /><br /><br /><br /> <br /><br /><span<br/>style='font-size:12.0pt'>On 10/5/05, Mary<br />McClure <mary.mcclure@unisys.com<br />> wrote:<br /><br /><br /><br />Has anybody tried to use the COM interface to epic.exe via a .NET<br />application? <br /><br /><br /><br />I'm currently still stuck on Epic 4.4. When I try to add a reference to the<br />Epic Type Library in Visual Studio .NET 2003, Visual Studio complains "A<br />reference to 'Arbortext Epic Type Library' could not be added. Converting the<br />type library to a .NET assembly failed. Could not load type Epic.TableSetClass<br />from assembly Interop.Epic, Version=4.4.0.0"<br /><br /><br /><br /><br />Looks like I'll have to write my cool app in VB6? I've interacted with the Epic<br />Type Library via VB6 just fine in the past. Has anybody out there successfully<br />written a .NET app that used the Epic Type Library (4.4)? How about the Epic<br />5.1 Type Library? >> To unsubscribe from the list, send an email to <a<br/>href="mailto:listmanager@maillist.arbortext.com" target="_blank">listmanager@maillist.arbortext.com<br />with the following in the body: unsubscribe adepters - For additional<br />information on the adepters list (how to subscribe or unsubscribe etc), send an<br />email to: listmanager@maillist.arbortext.com<br />with the following in the body: info Adepters - You may also go to <a<br/>href="http://forums.arbortext.com" target="_blank">forums.arbortext.com,<br />enter the Adepters folder and change your subscription options and<br />preferences.>> <br /><br /><br /><br /> <br /><br /><br />
