Catalog proliferation
AndyEsslinger
Newbie
Adepters,
I am transitioning from Epic version 4.2.3 to version 5.1A and I have a
problem with the way the new version places catalogs. For some reason
the new Epic is putting catalogs in each folder where it is used instead
of using a central catalog like the old version did.
Is there a way to stop this behavior? The APTCATPATH variable points to
the doctypes directory, and I seem to remember that there used to be a
way to make Epic use a specific filename as a catalog. I've looked
through archive posts without finding it.
Teach me about catalogs,
-Andy
\ / Andy Esslinger - Lockheed Martin Aeronautics Company
_____-/\-_____ (817) 777 3047 LM Aero Ft. Worth F/A-22 TOD
Integration
\_\/_/ Box 748 Mail Zone 4285 Ft. Worth, TX
76101
Tags (2)
Re: Catalog proliferation
I've noticed some similar behavior, and I'm not sure what triggers it.
We have our APTCUSTOM set, and the catalog file resides at custom/doctypes.
When I go to "install" a doctype, I've noticed that it always asks for a
public ID. When you click OK, it either contains the current public ID (it
found it in the catalog), or it's blank and I have to fill it out (didn't
find the catalog), and it's usually under this second circumstance that I
have noticed "rogue" catalog files showing up inside our custom doctype
directories. As far as I know, when the custom dir loads, it prepends
catalogs from any subdirs of custom/doctypes, and then prepends the catalog
file at the root of custom/doctypes, so I can't say it's ever caused a
problem, just an annoyance.
On the other hand, I rarely use the "install" function in architect to
update a doctype. I usually just move the changed file over and
compile_doctype, and under this circumstance, i've never ended up with an
extra catalog.
-Jason
Epic still has a central catalog. It is $APTPATH/doctypes/catalog.
Actually, this catalog is the root of a catalog tree. In this catalog
(either 4.2.3 or 5.1A), there are lines like this:
CATALOG "axdocbook/catalog"
to include other catalogs.
Maybe I don't understand your question, Andy, but I suspect catalog
support hasn't been changed much since 4.2.3.
Tung
A colleague just explained to me that I did misunderstand your question.
Sorry about that, Andy. Jason's reply was on the target.
Tung
