Catalogs and http://
Highlighted
Newbie
Many thanks for your efforts, Paul.
An upgrade to 5.1 solved this problem completely.
Paul Grosso scribbled on 3/11/05 3:08 PM:
> Peter,
> I don't have access to 4.x myself, so my best guess
> is that what should and does work in 5.x isn't quite
> working for you in 4.2.1.
> Someone in Support can access the older versions.
> If you send them the setup that I used, they should
> be able to test with 5.1 and 4.2.1 and tell you if
> what works in 5.1 works in 4.2.1 or not.
> paul
Tags (2)
