Change default language in Arbortext Editor
rboneti
7-Bedrock
Hi all,
Someone knows how can I change the default language in Arbortext Editor?
I know how to change it using the styler, but without styler, I mean, using only the Editor I haven't found where.
Hi Robson
It might depend on how your setup is configured, but for example if you have an application/custom specific \init\myprefs.acl you can include lines as:
$ENV["LC_MESSAGES"] = "en"
Regards
Chris
Chris,
It's to change the language of the interface. I need a solution to change the language of the version of the xml or sgml I'm working. What I really need is a multi-language function, because I'm constructing a document that needs to have versions in English, Portuguese and French.
lfraley
(To:rboneti)
Are you asking how to change the attribute that indicates to the processing pipeline that the text in the source file is not english?
If you're in DITA, change xml:lang; In DocBook, it's lang. Use the proper language code.
TimPhelps
(To:rboneti)
Did Liz's information help you to resolve the issue?
Tim
