How do I change the name of an element? If I can't then how do I create a new element?
Hi Anisah,
Go to the Arbortext Editor Help Center and search for Alias Map Overview, which describes how to change the name of elements and attributes.
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
Hi Anisah,
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
Hey Anisah,
Were you all set with regard to this issue, or did you have any follow-up questions?
Thanks!
