Creo Illustrate figures list not displaying images
Regular Member
We have an issue with the Figures list not showing the thumbnail images for one particular user. None of our other users have this problem. Could there be a setting somewhere that is flipped, or a bug? If he opens a .c3di created by someone else, he will get a temporary glimpse of the images, but then they disappear as soon as he starts working. You can imagine the frustration of determining the image you need when you have to click through them all the time. Version 3.1 M010 build 27.
Thanks guys for any input.
19 REPLIES 19
Re: Creo Illustrate figures list not displaying images
Did you ever get an answer to this issue?   We have a user with the same problem, but in Creo Illustrate 3.0.
So far we have tried the following:
- update video driver
- uninstall Illustrate and re-install
Still not fixed
Creo Illustrate 3.1
I have had a similar issue a few times. It happened yesterday again.
I've have the issue in the photo above, and also another where a figure will display an image, but when clicked on, it changes shows another image.
I've experimented to see if I could find what causes it, by creating many images and deleting some, saving and reopening multiple time, but could not recreate it.
Anyone learned what causes it yet?
We have not found a solution yet either.
You can try to delete your user_prefs.xml from your c:\user\(your username)\AppData\Roaming\ptc\Illustrate folder.  I think that will bring them back if I remember correct.  Just not doing that removes any preferences you may have set in illustrate.
Thanks for the suggestion Brian. Unfortunately in the user_prefs.xml, I have some custom colors set, and also some paths to a shared symbols tools library. I may give that a try though if need be. Revising the .xml could be easier than redoing the figures!!!!!!
I just lost images again. I tried deleting the user_prefs.xml, but that did not do the trick. I was hoping it would. Very frustrating.
What version of Illustrate are you using?
You could also try to rename the whole illustrate folder.  ( c:\user\(your username)\AppData\Roaming\ptc\Illustrate)  That may work as well.
3.1 M010 build 27
