Custom Dir Variable
berard
Custom Dir Variable
After changing our deploy to use a server-side custom.zip (auto patch
deployment), we realized that there is one place in our code that looks for
a stylesheet in the custom dir. This was previously hardcoded to
"c:\program files\..." which of course no longer works.
Does anyone know offhand if there's a variable to find the path of the
current custom dir? I'm hoping to have it point to:
C:\Users\[USERNAME]\AppData\Local\PTC\Arbortext\Editor\.aptcache\zc\1\custom\stylesheets
or equivalent, so I'm thinking something like $CUSTOM_PATH + "\stylesheets"
would do the trick.
keith
6 REPLIES 6
byork
(To:berard)
APTCUSTOM in the variable.
Hi Keith--
I think get_custom_dir() is the function you want.
--Clay
Clay Helberg
Senior Consultant
TerraXML
byork
(To:berard)
I agree with Clay if you are using acl get_custom_dir() is correct.
bibach
(To:berard)
Bear in mind that it is possible to have multiple custom directories
set at once. I've used this to maintain a separate custom directory
for code specific to a particular version of Arbortext (I have 5.3,
5.4 and 6.0 all installed side-by-side, for various projects) in one
custom directory and version-independent code in another, or for
project-specific code in one directory and project-independent code in
another.
Given this, perhaps your best bet is to locate the stylesheet
directory relative to the location of the document type for the
current document (e.g., doc_type_dir() . '..\..\stylesheets').
-Brandon 🙂
berard
(To:berard)
Yeah, I think that might be a better solution. get_custom_dir() returns:
C:\Program Files (x86)\PTC\Arbortext Editor\custom\
The other did the trick: (java)
Acl.eval("doc_type_dir()") + "\..\..\stylesheets\renderlogic13.xsl"
Thanks!
On Wed, Feb 29, 2012 at 2:16 PM, Brandon Ibach <
> another.
> -Brandon Smiley Happy
> On Wed, Feb 29, 2012 at 1:58 PM, Clay Helberg <chelberg@terraxml.com>
> wrote:
> > Hi Keith--
> > --Clay
> > Clay Helberg
> > Senior Consultant
> > TerraXML
> > From: Keith Berard [
> > or equivalent, so I'm thinking something like $CUSTOM_PA...
Hi Keith--
In that case, I think you may have something misconfigured.
get_custom_dir() should give you the location of the cached expanded zip
folder when using zipped customizations. From the online help:
In cases where APTCUSTOM cites a zipped custom directory, application,
or CMS adapter, get_custom_directory returns a full path to the locally
expanded form of the zipped customization. The expanded form is stored
in the Arbortext Editor cache (.aptcache\zc) directory. For example, if
APTCUSTOM is set to the following value:
