Can someone please tell me if it is possible to customize keyboards shortcuts in IsoDraw 7.0? I know that there is a default set of keyboard shortcuts but I am interested in making my own. I have searched high and low for the answer to this and everything I have read thus far leads me to believe it is not possible. I cannot believe IsoDraw has not implemented this type of functionality into their software at this day and age.
I think that it's not possible.
Yeah. I tried to find this functionality in isodraw 7.3, but unfortunately I didn't find.
did you know if this was implemented in I.D 7.3?
it's a big fault of PTC in this point.
Have been asking for multiple years. Hasn't happened. The closest is the custom toolbar which is not as handy and has it's own set of limitations.
As a note, when we started we were by the salesperson that you could do custom shortcut keys. After the purchase I couldn't figure it out so I finally got in touch with a tech that was assisting with initial questions and was told that function was not present.
I doubt it will be added as PTC has indicated they're focusing on Illustrate by introducing more 2D functions and the eventuality that Illustrate will replace IsoDraw. Don't know timing, but that would seem to indicate that new features will be limited to high payback.
BTW, we're on 7.3, M031 and custom shortcut keys are no where to be found.
