<br /><br />Thank you.<br /><br /><br /><br /><br /><br /><br /><br /> <br /><br /><br /><br /><br /><br /> <br /><br />From: steve.cuzner<br /> <br /><br />Sent: Monday, June 26, 2006 5:29<br />PM<br /><br />To:<br />Adepters@maillist.arbortext.com<br /><br />Subject: Re: Custom look of E3<br />output<br /><br /><br /><br /> <br /><br /><br /><br /><br /><br />I'm assuming based on your chunking question from earlier that you mean<br />E3 publisg to web output. If this is the case you can modify the viewer.css<br />file in your framesets directory and if this isn't enough and you are good at<br />multiple browser javascript coding you can dig into modifying the html and js<br />files in the frameset. <br /><br /><br /><br />Steve Cuzner <br /><br />Annulus Software, Inc. <br /><br />Providing Custom Publishing Solutions with XML <br /><br />401-441-5123 <br /><br /><br /><br />x >> To unsubscribe from the list, send an email to listmanager@maillist.arbortext.com with the following in the body: unsubscribe adepters - For<br />additional information on the adepters list (how to subscribe or unsubscribe<br />etc), send an email to: listmanager@maillist.arbortext.com with the following<br />in the body: info Adepters - You may also go to forums.arbortext.com, enter the<br />Adepters folder and change your subscription options and preferences.>> <br /><br /><br /><br />
<br /><br />When I modify the viewer.css file should I<br />put it in the custom/framesets folder? Thanks.<br /><br /><br /><br /><br /><br /><br /><br />Another question: No one has responded to<br />this post. E3 doesn't add tables to the output HTML files therefore the<br />content runs off the screen and you have to scroll to the right to view the<br />content. Is there a way to make E3 wrap a table around the content? <br /><br /><br /><br /><br /><br /><br /><br />Thanks.<br /><br /><br /><br /> Mario<br /><br /><br /><br /><br /><br /><br /><br /> <br /><br /><br /><br /><br /><br /> <br /><br />From: steve.cuzner<br /> <br /><br />Sent: Monday, June 26, 2006 5:29<br />PM<br /><br />To:<br />Adepters@maillist.arbortext.com<br /><br />Subject: Re: Custom look of E3<br />output<br /><br /><br /><br /> <br /><br /><br /><br /><br /><br />I'm assuming based on your chunking question from earlier that you mean<br />E3 publisg to web output. If this is the case you can modify the viewer.css<br />file in your framesets directory and if this isn't enough and you are good at<br />multiple browser javascript coding you can dig into modifying the html and js<br />files in the frameset. <br /><br /><br /><br />Steve Cuzner <br /><br />Annulus Software, Inc. <br /><br />Providing Custom Publishing Solutions with XML <br /><br />401-441-5123 <br /><br /><br /><br />x >> To unsubscribe from the list, send an email to listmanager@maillist.arbortext.com with the following in the body: unsubscribe adepters - For<br />additional information on the adepters list (how to subscribe or unsubscribe<br />etc), send an email to: listmanager@maillist.arbortext.com with the following<br />in the body: info Adepters - You may also go to forums.arbortext.com, enter the<br />Adepters folder and change your subscription options and preferences.>> <br /><br /><br /><br />
