DITA DTD updation error in Arbortext
rnavath
2-Explorer
Hi Adepters,
I am trying to make optional title and desc to required element from DITA base file, tblDecl.mod by removing question mark(?) .
I am getting below error
[cid:image001.png@01CF7438.0D59E720]
If I remove question mark from title alone, its working fine.
Original tblDecl.mod file given below.
I'm guessing that the table that is out of context does not have any content from the %desc; entity, You may want to change the model to be allow %desc; to still be optional.
You will also get that error if you don't have a in the now. You may need to fix all occurrances where was not inserted previously in order to get the the document back into context.
The FOSI/stylesheet has nothing to do with making a document out of context.
Hope this helps,
Trudy
Hi Adepters,
o
I am not able to identify whether it is DTD error or arbortext FOSI error. Somebody can help me in this issue?
Roopesh Navath
Software Dev Assoc Engineer
Dell| PG – Information Development, India (BDC)
