I'm guessing that the table that is out of context does not have any content from the %desc; entity, You may want to change the model to be allow %desc; to still be optional.
You will also get that error if you don't have a in the now. You may need to fix all occurrances where was not inserted previously in order to get the the document back into context.
The FOSI/stylesheet has nothing to do with making a document out of context.
Hope this helps,
Trudy
Hi Adepters,
I am trying to make optional title and desc to required element from DITA base file, tblDecl.mod by removing question mark(?) .
I am getting below error
If I remove question mark from title alone, its working fine.
Original tblDecl.mod file given below.
o
I am not able to identify whether it is DTD error or arbortext FOSI error. Somebody can help me in this issue?
Roopesh Navath
Software Dev Assoc Engineer
Dell| PG – Information Development, India (BDC)
