DTD/schema change
Okay, I learned the other day that the 'clear_stylesheets' will clear loaded
style sheet files from the memory. Now I am playing with schema changes.
I've made some fairly major changes and put the updated schema into a new
folder.
What I need now is figure out how to change my test file from using the old
schema. I have removed the system identifier and the schemaLocation
information from the file, but Epic still insists on using the original
schema rather than saying it cannot find a DTD/schema.
I could copy files around so the new files are in the current path, but then
I will confuse myself (and I don't need help doing that anymore) as to which
is which.
Any help would be greatly appreciated.
Lynn
folder.
is which.
Lynn
