Detailed information on Arbortext Editor of XSL-FO
BillyWoo
Arbortext Editor online help said, "For detailed information on Arbortext Editor support of XSL-FO, refer to the Arbortext annotation of the W3C XSL specification, located at in the Documentation section of support.arbortext.com. For detailed information on Arbortext extensions to XSL-FO, refer to www.arbortext.com/namespace/XslFoExtensions/ati-xsl-fo-extensions.html." But these websites are all unavailable now. Does anybody know where is the information? Thanks a lot!
Hi Bill, do let me know if you know how to access the apis. Thanks!
lfraley
6-Contributor
(To:nmisra)
This page still resolves:
http://www.arbortext.com/namespace/XslFoExtensions/ati-xsl-fo-extensions.html
We should probably put a copy of this at the adepters code archive.. adepters.org
JingjunLong
(To:BillyWoo)
Hello Mr. Wu,
You can also find the document Liz described in arbortext folder on your local machine. It describes what limitation PE has on XSL-FO:
C:\Program Files\Arbortext\Editor\docs\ati_xsl_support
Jingjun
