Dimension too large error
apco
Has anyone else encountered a Publish to PDF File failed..due to Dimension too large error?
Trying to isolate the cause.
Tracey
mhatfield
(To:apco)
How big would you expect your output to be? I have published pdf files in excess of 20Mb...but nothing really much larger than that.
apco
(To:mhatfield)
The documents can get quite big... more well into the gigs, but that was not the issue.
I found the problem. It was to do with pulling content via xpath into a gentext table.
I tweaked it a bit and have managed to get the required output ... just needed to do it a smarter way
Tracey
