I've got two floatlocs for repeating Titles and Columnheads and I've been having trouble with them disappearing in one section only of my document, the last set of tags for that section. (Styler 5.4)
Tags are:
xxxx<codedesc>
<codetitle>xxxx</codetitle>
<description>Blah blah blah blah<note>
<para>Blah blah blah blah
</para>
</note>
<brk>Text
</description>
</codedesc>
I was trying to keep <codetitle> and <description> on the same page. When I added a keeps, they stayed together but then floats disappeared on the last page. If I hardcoded in the repeating titles, both titles and floatlocs showed up so I had sets of two repeating titles. If I took out the keeps, the description moved to the last page but the floats came back. Now I added extra spacing so they're on the same last page without the keeps, but the floats disappeared again anyway...
Thanks for any advice!
Caroline
I added in a last context to the parent element, forced a page break and hardcoded the repeating titles so my output at least matches the client's.
