Yes that is correct. You can publish non CGM graphic types without ISOview (some notation types require other plug ins).But if you want to use Hotpsotted CGM's you need the isoview distribution kit.
Ian.
I will enquire with ATX product management as to whether Isoview is ALWAYS required, even for JPEGS and GIFs etc.. I do not beleive so, but I will double check.
Ian.
