Is anyone aware if Documentum/WDK adapter and AE 5.3M050 will work on a Windows 7, 64 bit computer?
Thanks, Darquise Leblanc
I should say, it is not supported in that environment. Whether it "just works", I couldn't say. What version of Internet Explorer are you using? We got hard fails on IE8 (albeit in a Windows XP 32bit environment).
I think you need 6.x for 64 bit support.
I think you need 5.3 m190 for IE8 support for the WDK.
Got no clue about Windows 7 ...
This version connected to WDK. however, when testing I noticed that "Modify Attributes" kept freezing. I have now upgraded to AE 5.4 M090. So far I can connect to Documentum/WDK and no modify attribute errors. I will continue to test. Note that I am getting PE errors - I am currently troubleshooting this.
Thank you very much for you help!
