Does ACL "write" have a size limit?
TomLeoboldt
Is there an established limit for the size of a text string written to a channel using the ACL write command? We have encountered a few instances when using the write command where this appears to be true, but I have found no documentation of this limit. To be clear, here is the line of code we are referring to:
write($channel, $text_string)
Our testing has shown that when $text_string is greater than 4,095 characters in length, the call fails.
We are running Arbortext v5.4 on UNIX.
Any suggestions would be appreciated.
Tom
Hi Tom--
Yes, there is a limit to the length of strings that can be passed. The
usual way to handle this is to write smaller chunks, e.g. to write each
line as a separate operation. It's often done using an array of strings,
where each element of the array is a line.
If your string isn't line-based, you may just have to use arbitrary
breaks, e.g. every 4000 chars, something like this:
# write long string to output file
local $content = $text_string;
while (length($content)>0) {
write($channel, substr($content, 1, 4000));
$content = substr($content, 4001);
HTH.
--Clay
Clay Helberg
Senior Consultant
TerraXML
1380 Forest Park Circle, Suite 100
Lafayette, CO 80027
Thank you. We have implemented logic like that which you show below as a work around to the problem. I guess we will now think of it as the end solution.
Thanks again for your swift response.
Tom
