Arbortext Editor 6.0 and 6.1 uses lower version of JRE, to support custom plugin we need to upgrade Arbortext JRE to JRE 1.8.
Does PTC supports using Arbortext Editor 6.0 and 6.1 with JRE 1.8?
PTC only supports the version of Java that is shipped with Arbortext. For 6.1 that is Java JRE 7, for 7.0 that is Java JRE 8.
