Greetings
This question might have been answered already but I can't locate the answer: Does one need Architect for the Import/Export to work?
Could one just have the Import/Export license working without the Architect and would one be able to import documents and create Map Templates?
Thanking you
Tshediso
You don't need Architect but you do need an Import/Export license. Import/Export can be attached to a desktop client or to PE (for use by many different people in the organization)
In our setup we have the Import/Export without using Architect.
We use the Import/Export strictly for RTF generation.
Arbortext Architect and Arbortext PE both do include the Import/Export Workbench which is used to develop the map file.
