Hi Alex,
Thanks for raising this point. This issue has caused me consternation at
least twice. It's the sort of thing that happens infrequently, and the
resolution can be easy to forget.
Changing doctypes in the E3 install path may require some caution if you
upgrade E3 to a version down the road. It's probably better to put these
in [Epic-path]\custom\doctypes.
In my experience, the following steps solved the problem:
1. Check to ensure all files required for the doctype are present
(especially the catalog file).
2. Ensure that no files in the [Epic-path]\custom\doctypes directory (and
subdirectories) are set with "read only" permissions.
3. Restart the E3 service.
Jason
alexs <alexs@documentum.com>
02/07/2006 12:47 PM
Please respond to
<adepters@arbortext.com>
To
<adepters@maillist.arbortext.com>
cc
Subject
E3: installing new doctype
I have a pretty basic problem.
When trying to publish a document that uses a new doctype I created on E3,
I get an error stating that the doctype hasn't been installed on E3.
This is how I installed the new doctype:
I created a directory called scrdaxdocbook in the C:\Program
Files\Arbortext\E3\doctypes directory; in the scrdaxdocbook directory, I
have a catalog file with this public identifier:
PUBLIC "-//EMC//DTD DocBook XML V4.0//EN" "scrdaxdocbook.dtd"
I also have an scrdaxdocbook.dcf file and numerous other files--mostly
copied from the axdocbook directory and I changed their "axdockbook"
portion of their file names to "scrdaxdocbook". I also did a search and
replace within those files from "axdockbook" to "scrdaxdocbook".
I rebooted the E3 server machine.
I created the same directory on my local machine w/epic editor and my
document that uses the scrdaxdocbook.dtd opens up without any errors.
W! hat am I doing wrong?
thx--alex >> To unsubscribe from the list, send an email to
listmanager@maillist.arbortext.com with the following in the body:
unsubscribe adepters - For additional information on the adepters list
(how to subscribe or unsubscribe etc), send an email to:
listmanager@maillist.arbortext.com with the following in the body: info
Adepters - You may also go to forums.arbortext.com, enter the Adepters
folder and change your subscription options and preferences.>>
