Edit Selection as XML Source in 5.3M130
ptc-3063012
We were using AT 5.3M010 which had bug issue and so now we have 5.3 M130. I don't see "Edit Selection as XML source" in this version of AT.
Karthik
5 REPLIES 5
Hi Karthik-
Make sure you have "Full menus" enabled in your preferences. I think
this is off by default.
--Clay
We're only at 5.3 m110 but we still have it. Is this possibly a fullmenus
thing? Issue "set fullmenus=on" on the command line and try again.
On Fri, Mar 12, 2010 at 12:15 PM, Karthik Kumar <
karthik.kumar@merrillcorp.com> wrote:
> Hello,
> Karthik
How can I forget the basics?!?!?! Too bad. Thanks Clay. It works now.
On Fri, Mar 12, 2010 at 12:55 PM, Karthik Kumar <
I got bit by the "is it plugged in" question just the other day. No,
literally, it wasn't plugged in. Ah well ...
Paul Nagai
When I was a calibration technician in the Air Force, we would sometimes get trouble calls about electronic equipment. More than once we asked the question: "Is the O-N O-F-F switch in the O-N position?" The answer would frequently be, "Ohhh...no...heh heh..."
