Embedded XUI - JavaScript
ptc-4796391
Hello again,
Does anyone have experience with embedding the XUI form? I know little JS however the problem I am having is finding a reference to 'prefixes' (Application.event.target for example), also I am not sure what event's could be used (so for example onClick - does it even exist in XUI?).
One of the examples of what I am trying to do:
I would like to add textbox with a new id when the button with lablel 'Add Company Name' is clicked - I understand the logic, go to box object with id="coname", count textboxes, add new textbox with counter+1, however it is really hard to say what to use, for example 'Application.something' or 'Application.event.target.' or anything else (I am not sure how many 'prefixes' exist). Does anyone have a JS reference that they use while implementing embedded forms? or any examples of embedded forms?
<box id="coname">
<label label="COMPANY-NAME"/">
<textbox id="1">
<value></value>
</textbox>
<textbox id="2">
<value></value>
</textbox>
<button label="Add" company=" name&quot;="></button>
<script type="application/x-javascript" ev:event="domactivate">
//var test = Application.document.getElementbyId('coname');
Application.alert('test');
</script>
</box>
Any help would be really appreciated, as always!
Marcin
7 REPLIES 7
Hi Marcin--
Where the "prefixes" are used in XUI is primarily to get the document
that forms the basis of the dialog, so you can modify it in the way you
describe. You can typically do this by using
Application.event.target.ownerDocument. From there, you can use
getElementById() to find the thing you're looking for, and the usual DOM
methods to modify the tree. For the example you describe, the code would
look something like this:
<window>
<box id="coname">
<textbox id="t1">
<value></value>
</textbox>
<textbox id="t2">
<value></value>
</textbox>
</box>
<script ev:event="domactivate" type="application/x-javascript">
// get the dialog document object
var dlgdoc = Application.event.target.ownerDocument;
// now get the target box
var box = dlgdoc.getElementById("coname");
// create a new textbox
var tb = dlgdoc.createElement("textbox");
// set the ID attribute
tb.setAttribute("id", "t" +
(box.getElementsByTagName("textbox").length + 1))
// create the child value element and add it
var val = dlgdoc.createElement("value");
tb.appendChild(val);
// finally, add the new textbox to the exiting box
box.appendChild(tb);
</script>
</button>
</window>
A couple of things to note:
1) The <script> element that we want to trigger when the button is
pressed needs to be inside the <button> element. (There are other ways
you can tie them together with the event attributes, but this is the
easiest way to do it.)
2) You probably want the <button> element to be outside the box, so
you can freely add new fields to the box without worrying about where
the button is.
3) The allowed events are described in the help center, under the
title "Event Types". For most things where you want to react to a click,
DOMActivate is the event you'll want to listen for. The mouse events
tend to be limited to the edit window, they are not very useful for XUI
dialogs.
Hope that helps. Happy XUI development!
--Clay
Clay Helberg
Senior Consultant
TerraXML
I should also point out that in addition to the samples provided by the
Arbortext install, there's quite a bit of sample code up on
Hi Clay
Great reply, thanks for the information, very helpful!
Is there a reference where I can find information about the 'prefixes'?
Marcin
In Reply to Clay Helberg:
Hi Marcin--
<window>
<box id="coname">
<textbox id="t1">
<value></value>
</textbox>
<textbox id="t2">
<value></value>
</textbox>
</box>
</script>
</button>
</window>
the button is.
dialogs.
--Clay
Clay Helberg
Senior Consultant
TerraXML
I'm not 100% sure what you mean by "prefixes", but there is fairly
complete documentation on the Arbortext Object Model (AOM) interfaces
and methods in the Help Center. The information is primarily in the
Programmer's Reference, which is in the Help Center as both HTML topics
and as one large PDF.
The sort of thing I think you might mean by "prefixes", such as
Application.event.target, is really just a composite object reference.
It means, "get the Application object, and get the event object from it,
and then get the target object from that". It's equivalent to something
like this:
var app = Application;
var ev = app.event;
var tgt = ev.target;
but it avoids having to save the intermediate objects as variable
values, when all you really care about is the thing at the end. Each of
the objects is described in the API documentation (the "Interfaces"
section of the Programmer's Reference). For example, the Application
object is described, and its properties (including the "event" property)
and methods are listed.
Does that help clarify?
--Clay
Clay Helberg
Senior Consultant
TerraXML
Hi Clay/All
Thanks a lot for the previous answers, really useful stuff.
I am stuck at a weird 'bug' - any clue what could be wrong? Code below.
Also, is there a way to find out what exception is JS throwing when it fails?
Marcin
//this script is for the <window> element and the action is on WindowLoad
<script type="application/x-javascript" ev:event="WindowLoad">
var actdoc = Application.activeDocument;
//var xuidoc = Application.event.target.ownerDocument;
var myWindow = Application.event.target;
var xuidoc = myWindow.dialogView.document;
var parentElement = actdoc.getElementsByTagName('sample:parent').item(0);
var childrenElements = coreEnrichment.getElementsByTagName('sample:child');
//var childrenElementsLength = coreCompany.length;
//var childrenElementsLengthInt = parseInt(coreCompanyLength);
Application.alert(childrenElements.length); // THIS RETURNS 4
for (var i=0;i<childrenelements.length;i++)< p=">
//when I substitute 'childrenElements.length' with number 4 it does not break
//however if i use childrenElements.length which returns 4 in the alert box it just breaks the script
some code in here
</script>
You could wrap in a try { .. } catch (e) { Application.alert(e) } ?
Hi Marcin--
Gareth's idea is good general advice. Also, if you are using Rhino
javascript, it will often write error messages to the Java console. If
you show the Java console (Tools->Administrative Tools->Java Console)
and then run your code, you might see error messages indicating the
problem.
In this case, I think your problem may depend on the contents of your
loop (where you wrote "some code in here"). Specifically, if you are
modifying the structure of the coreEnrichment, such that the list of
childrenElements changes (for example, by deleting a child elment or
inserting a new one), that might explain why childrenElements.length
starts to throw errors in the loop.
You might be able to work around this by storing the value, basically
what you did with the test you described in the comments, except using a
variable instead of hard-coding "4", something like this:
var nchildren = childrenElements.length;
for (var i=0; i < nchildren; i++)
However, if you are modifying the elements that belong to the
childrenElements nodelist, you may still run into problems here, where
childrenElements becomes invalid. In that case, you may be better off
with a while() test that checks for descendants of the type you want to
operate on, rather than trying to iterate over a nodelist that is
changing on each iteration. For example, this often comes up when trying
to remove child nodes from a parent node. Code like this won't work:
for (var i=0; i = parent.childNodes.length; i++) {
parent.removeChild(parent.childNodes.item(i);
because you keep changing the childNodes nodelist. The way to do this is
with a while loop:
while (parent.hasChildNodes()) {
parent.removeChild(parent.firstChild);
--Clay
Clay Helberg
Senior Consultant
TerraXML
