Epic Response Message
donna_wolkenste
Good Day.
I am using Epic 4.3, with Print composer.
1) whenever I open a document I get the following error:
Epic Editor Response
winregistry: [A20272] cannot get Path in _ queryBinaryValue (6)
once I click on ok, I get another error which is exactly the same as the one above, and I click ok again, and then I can work in my document.
2) Also, when I am scrolling through the document within Print Preview, I get the following error:
Pubview.exe has generated errors and will close Print Preview, and will produce an error log
a vdebug.log is generated with the following content:
An error has occurred. The following chain of information is available:
error 1: /Return/Null/
message: No Windows resources (BITMAP)
errno: 2: No such file or directory
Has anyone encountered these two things happening? If so, how were you able to resolve this. I have uninstalled and reinstalled EPIC, but, that doesn't seem to work.
Donna Wolkenstein
Standard Aero
Donna,
We continually receive the second error
that you describe and have put in a case to Arbortext support. It has yet
to be solved.
Sean
<table width="100%">
<tr valign="top">
<td width="40%">"Wolkenstein, Donna"
<donna_wolkenstein@standardaero.com>
04/13/2006 12:52 PM
<table border=">
<tr valign="top">
<td bgcolor="white">
Please respond to
<adepters@arbortext.com>
</table>
<td width="59%">
<tr valign="top">
<td>
To
<td><adepters@arbortext.com>
<tr valign="top">
<td>
cc
<td>
<tr valign="top">
<td>
Subject
<td>Epic Response Message</table>
<table>
<tr valign="top">
<td>
<td></table>
</table>
Good Day.
(6)
my document.
is available:
message:
errno:
Donna Wolkenstein
Standard Aero
To unsubscribe from the list, send an email to listmanager@maillist.arbortext.com
with the following in the body: unsubscribe adepters - For
additional information on the adepters list (how to subscribe or unsubscribe
etc), send an email to: listmanager@maillist.arbortext.com with the following
in the body: info Adepters - You may also go
to forums.arbortext.com, enter the Adepters folder and change your subscription
options and preferences.>>
This is an e-mail from General Dynamics Land Systems. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
