Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
It's been a couple of years since I've had to do this trick and it doesn't seem to be available anymore.
The trick was that at one time Arbortext/PTC(?) allowed two licenses for Epic, one on a 'fixed' machine and one for 'portable' use.
I've upgraded laptops (from a dual core to quad core) and want to transfer the 'portable' license to the new laptop. The only license I see on the PTC site now is the one for my 'fixed' computer.
Has this feature been removed during my hiatus or do I have to call PTC to obtain the key. I didn't see anything on their site related to this.
There is still a home license, but it is now a separate item. It is a fully capable license at considerably less cost because it's the second portable license.
We can help you if PTC is problematic (they may not understand what you need) or if they direct you to a reseller that doesn't know the product.
