Epic schema bug?
ptc-953926
Epic schema bug?
Adepters:
We’re using a schema in our
doctype in Arbortext Editor 5.2, patch M040. I’ve defined a particular
attribute to be a union of two simple types:
<xs:simpletype<br/>name="sizeByNumber">
<xs:restriction<br/>base="xs:positiveInteger">
<xs:mininclusive<br/>value="1"/>
<xs:maxinclusive<br/>value="20"/>
</xs:restriction>
</xs:simpletype>
<xs:simpletype<br/>name="pickAll">
<xs:restriction<br/>base="xs:string">
<xs:enumeration<br/>value="all"/>
</xs:restriction>
</xs:simpletype>
Used as:
<xs:attribute<br/>name="display" use="optional" default="all">
<xs:simpletype>
<xs:union<br/>memberTypes="sizeByNumber pickAll" />
</xs:simpletype>
</xs:attribute>
Epic seems to like the schema, but won’t
let me enter an integer value for the attribute in the Modify Attributes dialog.
It shows a blank field (where it looks like I could type, but can’t) and
the keyword “all”. If I edit the tag as XML source and insert the
integer value, e.g., “13”, Epic doesn’t complain. If I do
the same thing but enter the value “21”, Epic reports an error.
So, it seems to be processing the schema correctly.
Can anyone tell me how I can input the
integer value using the Modify Attributes dialog?
Dave
I was hoping maybe someone from Arbortext would at least
tell me if I need to open a (dreaded) PTC call.
<span<br/>style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:<font<br/>size=2 face=Tahoma>Sent: Friday, May 25, 2007 4:28 PM
To: adepters@arbortext.com
Subject: Epic schema bug?
<span<br/>style='font-size:12.0pt'>
Adepters:
We're using a schema in our
doctype in Arbortext Editor 5.2, patch M040. I've defined a
particular attribute to be a union of two simple types:
<xs:mininclusive value="1"/">
<xs:maxinclusive value="20"/">
</xs:restriction>
</xs:simpletype>
</xs:restriction>
</xs:simpletype>
Used as:
<xs:simpletype>
<xs:union membertypes="sizeByNumber" pickall&quot;="/>
</xs:simpletype>
</xs:attribute>
won't let me enter an integer value for the attribute in the Modify
Attributes dialog. It shows a blank field (where it looks like I could
type, but can't) and the keyword "all". If I edit the
tag as XML source and insert the integer value, e.g., "13", Epic
doesn't complain. If I do the same thing but enter the value
"21", Epic reports an error. So, it seems to be processing
Dave
<span<br/>style='font-size:12.0pt'>>> To unsubscribe from the list, send an email
to listmanager@maillist.arbortext.com
with the following in the body: unsubscribe adepters - For additional
information on the adepters list (how to subscribe or unsubscribe etc), send an
email to: listmanager@maillist.arbortext.com
with the following in the body: info Adepters - You may also go to
forums.arbortext.com, enter the Adepters folder and change your subscription
options and preferences.>>
