Error Message
ReeceJr2017
Error Message
App Publish
Error: Pg 1 New page sequence not specified; used fallback 'defaultPage'. [1035] (1:"editorDom0"#2;/})
i am very new using Arbortext, when i preview PDF page, the background color is red with elements showing
I agree with you... before your response i tried using different out of the box style sheets and some worked, I am learning arbortext, i was tasked with a parts catalog project and i am working on the cover page at the moment and like i said earlier when i reviewed the PDF it is in red and has elements displaying.  i am a newbie, i am currently going through all of the tutorials, documentation, etc.  but it is a a learning curve. i will be asking a lot of questions as i go.
This sounds like a stylesheet error, which is very unlikely in the "out of the box" stylesheets. You might need to track this down with whoever developed or supplied the stylesheets for you.
(What it's saying is it can't find the "page sequence" to use for the content, likely meaning that an unexpected context has been encountered)
