Error re-sourcing PE applications
vkadam
I am getting error in when I am sending concurrent request to PE.
Error like
com.arbortext.e3.E3RequestError: Error re-sourcing PE applications.
What should be the solution for it.
Thanks in advance.
Vijay
vkadam
(To:vkadam)
I am using following PE
Product:Arbortext Publishing Engine
Version:6.0 M060
System:Windows 7
TimPhelps
(To:vkadam)
Are you able to access the PE test page via a browser?
http://<computername>:8080/e3
If the port being used by Tomcat is not 8080, then use the appropriate port value in the above URL
Does the Version link work?
Does the ACL link work?
If not, then what error messages do you receive?
Are you able to open PE Interactive and compose a sample document?
Hi Tim,
Thank you for your reply.
I am able to access the PE test page via browser.
Yes, version and ACL links are working. Following is error image.07-09-2015 17-34-27.png
Vijay
