When I had my evaluation license everything worked great. But now with my new license I'm getting an error.
An unknown problem has occurred. I only get this when exporting a PNG file no other formats.
I have attached the error massage and the PNG export setting in the attachments.
Please let me know if anyone has a suggestion as to why this is happening.
Thank you
What are you using to build the image, any models, other images? I expect you are using version 7.4.3.0.
Bryon
It was created from a CATIA .STP file.
I am using Release 7.3
https://www.ptc.com/en/support/article/CS409448?source=search
Try setting the color image depth to 32 bit instead of 8 bit.
Bryon
I just opened a new blank page in IsoDraw and added two boxes and one string of text and got the same error.
I also tried opening a file that worked with the evaluation license, and it is now giving me the same error.
I know this is not the case, but it acts as though the PNG exporting capabilities have been removed.
Hmm we deal with JT files and export to cgm. I just opened a .stp file here and exported to png with no issues. All you did after the trial is change the license file?
Bryon
It seems odd, I would submit a support ticket to PTC and see what they can find out.
Bryon
I agree, and I just tried uninstalling and reinstalling IsoDraw and Creo Illustrate and it did work. I don't think one as anything to do with the other, but it was worth a try.
Thank you for your help
Jeff
I was not aware you had also installed Creo Illustrate. There could be some weird issue with install order. I like to install Isodraw first then Editor. I am glad you got it working.
Bryon
I'm sorry, I meant to say it did not work. I think I'm going to uninstall both and only install IsoDraw and see what happens before installing Creo Illustrate.
Sorry for the confusion
Good Idea.
Bryon
