Currently we use predefined template sizes in Isodraw, once the image is complete we export to cgm, insert in editor and publish to pdf. Everything looks good. If I use the same process, but export to SVG The image size changes and the extents of the image borders is not obeyed. What are the settings that we should be using in Isodraw so our template sizes are obeyed?
Once we get that issue solved is there a way to use the same image sizes for web output or do we have to go in and modify the SVG image settings? If we want the images to scale for mobile devices are we going to have to set the scaletofit to yes?
Bryon
