Hi All,
I don't know ACL (can barely spell it) - but I need to know of a simple way of extracting a list of all of the graphic entities in use in my XML doc (as what I'm really trying to do is to both eliminate / delete unused graphic entities, as well as eliminate / delete graphics that I'm not using in my current XML doc.)
I can see them in the Arbortext Graphic Entities ('Count Uses') Dialog box, but I don't know how to dump them out to a text file, .csv, .xls or whatever - some format that I can rack and stack them in.
It's a military XML tech manual (LOGSA MIL-STD 40051-2 chg 3, ASRL Construct 3.27, Stylesheet Fileset V1.8)
I know one of you gurus can pass me a simple ACL command line whoozit to dump the list of used/unused graphic entities.
Barring that, I'm relegated to screenshotting and OCRing a gazillion pages of the Arbortext Graphic Entities Dialog box ('Count Uses'), in order to rack and stack the list of 1500 plus graphic files to eliminate some 500+ of them that I don't need - and need not have them in the batch for processing or delivery.
So, if one of you folks would be so kind... (consider it like a 'green' gift... save so many of the OCR pixels from being wasted.)
Bob Williams
Tech Research Group Inc.
(a tiny little TM shop in Rhode Island)
TEL 401.434.4680 (Office)
EMAIL Robert.Williams@TechResearchGroup.Com
This might inspire you, Bob:
http://www.adepters.org/index.php?title=How_to_remove_unused_graphic_entites_from_a_document%3F
