Hi Adepter's,
I have one circumstance where an incorrect
page number is appearing in our FOSI generated TOC. Let's say that I have
the following mark-up and this mark-up composes to be on the same printed
page:
<part>
<subtopic>,,,,</subtopic>
<section>
<subtopic></subtopic>
</section>
</part>
And our folio (page number) consists
of following:
(part no.)-(section no.)-(page no.)
The situation is this, both subtopic's
appear on the same FOSI generated page of 1-1-1 (Part 1, Section 1, Page
1). However, the FOSI generated page number in the TOC for the first subtopic
(located directly before section in the SGML file) is 1-1 (Part 1, Page
1) which is incorrect as it should be 1-1-1. The FOSI generated TOC page
number for the second subtopic is 1-1-1, which is correct.
At the time the TOC savetext is performed
for the first subtopic, the section count is at 0 so I though if I used
the string variable modifier BO for the section count variable in the savetext,
this problem would be solved. But alas, no cigar. I'm sure that there is
some simple solution to this problem but on the other hand, I could be
dreaming. Any help would be appreciated.
Sean
This is an e-mail from General Dynamics Land Systems. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
