FOSI editing
ebenton
FOSI editing
Never mind. I found it in preferences. There is an option to "Remove Arbortext PIs on save".
8 REPLIES 8
Thanks Ed. Saved me some money you did.
Would you recommend a simple DTD or schema for a simple book like the operators manual in your car? Probably a good Arbortext one out there I just need to stumble across. Trying a commercial book and am trying to get away from the overly-complex Army-type.
Eventually it would be imported into an S1000D system but there is neither the time nor the budget to worry about that now.
John T. Jarrett CDT
Senior Tech Writer, Integrated Logistics Support,Land & Armaments/Global Tactical Systems
T832.673.2147 | M 832.363.7234 | F 832.673.2376| x1147 | -
BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
www.baesystems.com
bibach
(To:ebenton)
When I need a document to "play" with in Editor, I usually go with the
Arbortext-supplied version of Docbook. However, for a project with a
little more scope, particularly one intended for the sort of modular
maintenance approach espoused by S1000D, I think it would be only
moderately more work, initially, to start a DITA bookmap and create
concept, reference and task topics as needed. These topics should
readily map to S1000D data modules, while the bookmap would be
translated to whatever form your S1000D system uses to organize
modules into a print publication.
-Brandon Smiley Happy
On Wed, Jan 26, 2011 at 3:49 PM, Jarrett, John T (US SSA)
> Thanks,
> John T. Jarrett CDT
> www.baesystems.com
lfraley
(To:ebenton)
If you have 5.4, you might try the SMA (DITA specialization). It's got
samples that might be reasonable starting points.
I agree. Going along with DITA is closer to the S1000D design. It has some
quirks of its own and features you would probably want to stay away from
if you intend to go to S1000D. The good thing about it is the DITA Open
Toolkit. With that you can complie your output to PDF or HTML help without
having to buy anything.
Not sure what tools you have from PTC, but if you have PE or digital media
publisher you could get similar outputs from that as well. OT will have
xsl/xslt stylesheets that you can tweak directly, the PTC products I
belive use Styler stylesheets.
..dan
>> Thanks,
>> John T. Jarrett CDT
>> www.baesystems.com
For the record, these PIs are used by the style panels interface. They are
inserted when the FOSI is opened in the FOSI style panels interface and then
saved in either interface. PIs are inserted by the FOSI tagged
interface.
Suzanne Napoleon
"WYSIWYG is last-century technology!"
www.FOSIexpert.com
Is the automotive DTD from SAE apparently formerly called J2008 and/or T2008 dead? References in Google show it right up until 2004, then nothing. Not found under that name on their website, either.
John T. Jarrett CDT
Senior Tech Writer, Integrated Logistics Support, Land & Armaments/Global Tactical Systems
T 832.673.2147 | M 832.363.7234 | F 832.673.2376 | x1147 | -<">mailto:->
www.baesystems.com
lfraley
(To:ebenton)
Hi John,
I think I have a copy. I'll dig it out and send it to you when I find it.
Liz
On Thu, Jan 27, 2011 at 7:48 AM, Jarrett, John T (US SSA)
> John T. Jarrett CDT
> Tactical Systems
> www.baesystems.com
