FOSI enumerating at wrong level
JeffStevenson
Hello everyone,
I'm trying to code around what I believe is a bug in Arbortext 6.0 when numbering list items. In short, Arbortext is continue the numbering from a sublist onto the next item in the parent list.
I'm trying to develop a workaround by adding a new counter for the sublist. However, my counter is enumerating at the wrong level.
Consider the following markup....
<amend>
<provbody>
<prov>
<subprov><label>1</label></subprov>
<subprov><label>2</label></subprov>
....</amend>
I want the subprov/label to increment. However, what I am seeing happen is the enumeration is occuring at the <amend> level instead. So...
<amend>
...<subprov><label>1</label>
</amend>
<amend>
...<subprov><label>2</label>
</amend>
My Xpath to set the counter is working correctly as this is not obstructing the list higher up in the XML. But I cannot see how to get FOSI to enumerate within the <amend>.
Here is my FOSI that is setting the counter.
<att>
<specval attname="gentext-only" attloc="system-var" attval="#ANY"/">
</att>
Thanks for any assistance!
Hi Jeff,
Your code does not appear to be using FOSI enumeration. The problem would seem to be with the ACL and/or XPath.
Here is the native FOSI coding for your markup:
<counter initial="0" enumid="labelct">
<e-i-c gi="label" context="subprov">
<charlist inherit="1">
<enumerat increm="1" enumid="labelct">
<usetext source="labelct" placemnt="before"></usetext>
</charlist>
</e-i-c>
<e-i-c gi="amend">
<reset resetlist="labelct">
</charlist>
</e-i-c>
HTH.
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
Jeff,
[I was just about to send this and noticed Suzanne had sent out essentially the same solution. So let me just pile on.]
If your problem is simply about list numbering, then we pre-Styler FOSI jockeys would do that by using FOSI code like the following.
<counter initial="0" style="arabic" enumid="labelct">
<e-i-c gi="prov">
<charlist>
</charlist>
</e-i-c>
<charlist>
<usetext source="labelct">
</usetext>
</charlist>
</e-i-c>
[Or maybe instead of resetting labelct in the e-i-c for "prov" you'd want to do it in the one for "amend"?]
--Jack
LSI, Inc
Jacksonville, FL
