Brandon,
Never did see anyone reply, and finally had a couple of minutes today, so...
In order to see the trace data, after doing "set gentexttrace=#ALL", I click the "Update Gen Text" button in the markup tool bar. Since I'm running in Architect, that causes the "Arbortext Architect FOSI Generated Text Messages" window to display, containing the trace data, along with the update of the gentext in the Architect window. Not sure what the trace data window is titled when running in Editor.
Afterward, I have to go to Tools->Preferences->Advanced to turn off my gentext (don't usually run with it 'on', because of file sizes).
Don't personally know whether it is supposed to display when you do a Compose->PDF File...
HTH,
Steve Thompson
TAD Technical
Boeing-IDS Technical Publications
+1(316)977-0515
MC K83-08
The truth is the truth even if nobody believes it, and a lie is a lie even if everyone believes it.
>NOTICE: This communication may contain proprietary or other confidential information. If you are not the intended recipient, or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this e-mail in error, and delete the copy you received. Any and all views expressed are the current understanding of the sender and should not be interpreted as an expression of official Boeing Company policy or position.
Les renseignements contenus dans ce message peuvent être confidentiels. Si vous n'êtes pas le destinataire visé ou une personne autorisée à lui remettre ce courriel, vous êtes par la présente avisé qu'il est strictement interdit d'utiliser, de copier ou de distribuer ce courriel, de dévoiler la teneur de ce message ou de prendre quelque mesure fondée sur l'information contenue. Vous êtes donc prié d'aviser immédiatement l'expéditeur de cette erreur et de détruire ce message sans garder de copie.
