Find and Replace Line Breaks
ptc-1050369
Hello, We recently upgraded from Adept 9.0 to Arbortext 5.3. When we open a file in Arbortext that was created in Adept, line breaks are inserted after each line of text. Please advise how to either prevent the line breaks from being inserted, or search for & replace the line break character in the file. Thanks Ann
lfraley
6-Contributor
(To:ptc-1050369)
This can be a tricky proposition. A couple of months ago, someone posted to the Adepters mailing list that they'd done a general search & replace and ended up with wordsstucktogether because the line break character functioned as whitespace separating words. I don't remember what he finally ended up with, but a post to adepters would give you the answer.
Info on the adepters mailing list is below.
Cheers,
Liz
Adepters Mailing list hosted by PTC/User
The PTC/User portal (http://www.ptcuser.org) hosts the long-running Adepters mailing list. This list started in 1996 and has always been monitored by the PTC/Arbortext software engineering staff. Many long-time users and tools folks also regularly monitor the list. If you have a question, it's a really good resource as questions generally get answered within 24 hours. Beginning and advanced questions encouraged.
The List Email Address is: -
You can join the list from the PTC/User portal: http://portal.ptcuser.org/p/fo/si/topic=21
