Hi Gang,
I was working in IsoDraw 7.4 and I noticed that my "Layers" window would resize the width. I looked at the IsoDraw_7.4_Prefences.prf but was unable to decipher the formatting. Here is what I see when I open the preference file;
Usually I will a starting comment line showing the structure of the section, it does not show in this instance. Could someone please tell what the numbers represent? I don't want to go changing numbers and just see what happens.
Thank You,
Keith
