'Formatter Messages' list
steve.thompson4
Good Morning Adepters (it is morning, here), 🙂
Does anyone know where we can find a list of the 'numbered' warning messages that appear in the 'Arbortext Editor Formatter Messages' window? Example: [A12622] Warning: A horizontal graphic overset fault occurred. The graphic is too wide by 25.44pt.
It's not that we lack understanding of the above message, but that there can be a large number of such in a book of 1800+ pages. We need to know the 'number' for specific types of messages, to allow reliably searching that window for those types.
Thanks for any help,
Steve Thompson
TAD Technical
Boeing-IDS Technical Publications
(316)977-0515
MC K83-21
"It's only broke if someone notices it." - Tresa Spencer
> NOTICE: This communication may contain proprietary or other confidential information. If you are not the intended recipient, or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this e-mail in error, and delete the copy you received. Any and all views expressed are the current understanding of the sender and should not be interpreted as an expression of official Boeing Company policy or position.
Les renseignements contenus dans ce message peuvent être confidentiels. Si vous n'êtes pas le destinataire visé ou une personne autorisée à lui remettre ce courriel, vous êtes par la présente avisé qu'il est strictement interdit d'utiliser, de copier ou de distribuer ce courriel, de dévoiler la teneur de ce message ou de prendre quelque mesure fondée sur l'information contenue. Vous êtes donc prié d'aviser immédiatement l'expéditeur de cette erreur et de détruire ce message sans garder de copie.
Hi Steve,
I'm not sure if this is exactly what you're looking for, but I believe you
want to search for "ams", "amsgfmt", "amsgconv", and "amo" in the Help
index. You'll learn more about some ACL functions that can be used to
convert existing message files to other formats, retrieve message IDs, and
messages. Beyond that, you may need to contact technical support.
It appears as if the messages are stored in messages.amo, a binary file
inside [editor-path]/lib. If you work with additional locales, there are
message files for other languages in the [editor-path]/lib/locale folder.
One or more Adepters may have commented on this subject at one time or
another as well. There might be something in the archives on messages.amo.
Happy Friday (it's still Friday here),
Jason
"EXT-Thompson, Steve" <steve.thompson2@boeing.com>
05/18/2007 07:45 AM
Please respond to
<adepters@arbortext.com>
To
cc
Subject
Steve Thompson
TAD Technical
(316)977-0515
MC K83-21
copie.
Steve,
Jason is right on the AMO and AMS files. How they work with the internal operation, I haven't really dug into. You can see the message (along with the number), but they tend to be even more cryptic than the message displayed. There are numerous variables used in the AMO error messages. No further explaination to help understand the cause.
I once tried to follow the error number (thinking it might be an ID of some kind) back through and that was a dead end.
Good luck and if you find anything useful, let us know. 😄
Lynn
-----"EXT-Thompson, Steve" <steve.thompson2@boeing.com> wrote: -----
To: <adepters@arbortext.com>
