Good day all,
I have a .cgm file which contains illustrations related to manuals. It has lot of nodes in it. My aim is to create an single boundary for the entire illustration up to its extents. some of the lines are not joined correctly in the extents. If i apply generate contour, i am not able to get an proper boundary. Help me out in this situation. Thanks in advance.
Try to use "Fit elements" command (in main menu go to "Edit" -> "Move" -> "Fit elements"):
Is it possible to creater contour with these two steps in 7.1? I thought creating outerline(contour) in 7.1 is impossible?
Manoj
