Hi everybody!
I need to use the gentext of the table element to construct its header. In the table, there's an id in each, and the header change depending of the id value. So, I created a condition to test the id.
When I preview the document with "Editor Preview", it works well, but when I use the "PDF Preview", the gentext doesn't work, I mean, the text I write in gentext is ignored.
It happens only when I have a conditions, and only in the table element.
Hi Robson,
It may be simple, but is often overlooked. Make sure the output for the condition is not just set to Editor. I'm not certain why it may default to certain outputs (likely inherited from the parent), but it may be an issue.
If not, you may want to open a case, as this seems to be something we may need to reproduce.
