We are getting a segment 11 violation. With the explanation Warning: algroup nesting???
What version of Arbortext Publishing Engine are you working with?
There was SPR 2257743 / 2812883 reported in 6.1 M020, that was resolved in 6.1 M060 and 7.0 M010
"Pubtex is failing intermittently when composing certain documents to PDF"
Did the submission answer your question?
If so, then could you mark it as "Correct Answer"?
If not, then could you give more details about what products and versions that you are working with, and some detail about your use of algrouping?
