Hello, I use the app layout when it is now the xml file into a 3d file layout, but the changes in the 3d file is not synchronized to the xml,does the app has this feature can be 3d file layout changes in the synchronization to xml document?
hyifan
5 REPLIES 5
Yes, you can have content be linked into the .3D file. When you save the .3D it can then update the linked content with any changes you've made.
Thank you very much, if not may you trouble, can you say how to connect xml file and .3D file?
The relevant macros you should use are "tft*" "tlink" and "ttlchk".
Excuse me ,please kindly inform where can I find a tutorial on using "tft *" "tlink" and "ttlchk" to synchronize 3D files with XML files?
These macros are documented in the APP Help Center, but if you are not experienced and are after a tutorial then perhaps you need training. There are a number of providers of APP training services who can assist, some of who visit this forum. APP is a complicated piece of software to learn because of its wide range of features and deep functionality.
