Paul I really appreciate your time, here's a small part of my XUI document
window_create('xui',0x10,$doc) in my ACL script the window created shows me only a part of my content, it looks like, for example, some elements are hidden behind a
Thank you very much!!
Regars, Paulette Amparo
Hello again! 😃
Ok, so I'm still facing the problem =( I decided to attach an image of my problem, so I think maybe you could understand better my trouble and associatte it with any issue maybe you had. Hope this image would be useful, as you can see I add a yellow square which involves my created window, then I add a red figure which encloses the border (predefined I suppose) which doesn't let me to show all my elements. Does anybody knows how can I modify this kind of predefined size or maybe there's not an option to change it and I will have to adjust my design to this size? =(
As always I really appreciate your time and support.
Best Regards!
Paulette Zorrilla
Paul!
I really apreciatte your time and support, finally I've found that the tabpanel was the element which stablished the boundaries, I don't really know why, however I just decided to eliminate it, and finally I can see all my content inside my window, even if is docked.
Again, I'm pretty grateful because of your help.
Paulette Zorrilla
