Hide Attribute
ptc-3063012
Hide Attribute
In our schema we have a attribute called rowsep which is available in <table>, <row>, <colspec> and <entry>. I want to hide this attribute in all elements except <entry>.
I tried the dialoghidden option in the dcf file but that will hide the attribute in all element. Is there a workaround of this.
Karthik
Hi Karthik--
You might need to write some custom code and use it as a modify_tag
document callback. The code would need to check the current element
name, and if it's table, row, or colspec, withdraw the control for the
rowsep attribute.
--Clay
Clay Helberg
Senior Consultant
TerraXML
Okay. Thanks Clay.
