Hello
I try to use this hot key to popup a line in front another without success (on azerty keyboard , isodraw 7)
Anyone know why this command doesn t work ?
Thanks in advance.
I am a "longtimeIsoDrawuser" and I always use short cuts - but I've never heard about that one (strg+shift+=). Tell me more about - did it ever work in former versions?
I only know this ones around that point:
(strg+shift++ or strg+shift+-)
i m too a "long time user"
Before i used isodraw 6 and the shorcuts for popup and popback was like you use atm (ctrl + + to popup and ctrl + - to popback french version of isodraw).So i moved on version 7 and now the hotkeys are different : Ctrl+Maj(Shift)+ - to popback (this command work fine) for the other popup Ctrl+Maj(Shift)+= there s nothing happening , i have to "right click" and select "popup" it s annoying...
I think maybe because i push on Shift the = become + .....
Attached there s a picture of desktop....
thanks for your answer sorry for my english
Ah - now I know what you mean. I think it is a "translation" fault which is caused by PTC.
Here you can see how it is descripted in the german version - so I think you should use the button "+" instead of "=" ...
hehe i tried already to replace = by + but it doesn t work (you use the version 6 of isodraw ?) so i don t know what to do![]()
Maybe you know how to edit yourself the hotkey in isodraw ?
I think it s a bug in my version or a bad installation or the version 7 is less good than the 6 ![]()
It s totally weird
look the picture i have the same hotkey for "premier plan"(in front of all) work fine by element menu but "plan avant"(in front of another) doesn t work ........
pierre caz schrieb:
It s totally weird
That's really great ... I love that folks ... => open a call ... that seems to be a big bug ...
Oh that's nice when PTC makes differences in the functions between the different countries. ![]()
We use version 7.1 (from release M0010 to M0040) and here it works ... the best way for you may be to open a call at the PTC-support.
I agree with you it s not cool from PTC so i ll calling the tech support of PTC thanks for your time and answer see ya ![]()
