I have a FOSI for a document type which generates an LEP.
The LEP is generated by outputting the relevant page info from the pagespecs I have defined and it works fine.
However, what I don't have is any hotlink between the LEP entries and the matching pages.
I tried setting the 'hotlink' and 'status' attributes as I have for the TOC but to no effect.
I am beginning to think this is a limitation of generating the LEP content from the page spec rather than from the elements in the content as I have done for the TOC.
Does anybody know of a way to achieve hotlinks from the LEP entries?
Adrian Jordin
There are brute force options. We use an inline element with a IDREFS att, and generate those into the LEP entries by putting the markup into the savetext. You can also post-process with a little ACL to generate the links. Pagespec folios (and footers) can be a little goofy, especially with textvars and scoping.
