How can I configure the Compare tool to ignore non-ascii character encoding
stomlins
In Arbortext Editor you can select how to write non-ascii characters - either character entity references, numeric character references or characters.
If you are comparing a document that was saved using a different method for non-ascii characters the compare tool lights up like a christmas tree.
It would be nice to be able to configure the tolerance of the compare tool to ignore the difference of non-ascii characters that were written in different formats.
rdiaz
(To:stomlins)
Hey Sean,
This sounds like it might be a good candidate for an Idea request.
On the right side of the screen, when you're looking at the Arbortext Community home page, you should see an option to 'Create a Product Idea'. Depending on the response to that Idea, our Product Management team decides what new features to add to upcoming versions of the Editor. Thanks!
Hi Rafael
I don't seem to be allowed to submit an idea using the page you suggested.
"You are not allowed to create or update this content"
Cheers
Sean
rdiaz
(To:stomlins)
Sean, maybe try going from the main Arbortext Community page instead. This new interface may require a different approach.
On the Arbortext page, go to the Actions dropdown, and select it from there. See if that allows you to submit one:
stomlins
(To:rdiaz)
It seems that I'm missing that option. I suspect it's some kind of permission issue.
